Hi all! Once again I’m trying to visualize a luminaire sample I got to give an overview over my product. It’s a linear light with microprismatic cover and an additional PMMA cover polished.
As you can see on the photo of my sample, the illuminated microprismatic cover is projected onto the top surface of the PMMA cover which gives a nice depth-effect:
Mmmz, I see what you mean. I can imagine it doesn’t work if the PPMA is solid and there is no air/space on above the actual light in the 3D model you use.
Like if I try this and move the emissive part outside the actual PPMA (like it has a bit of empty space above the actual light) you see it disappears. Physics wise I think that makes sense as well. So try to make it so that the emissive part doesn’t actually touch the PPMA.
Thanks for trying! My emissive part is actually not “inside” the PMMA, but enveloped by it. But not touching.
Maybe my problem is the third party in my assembly, the microprism semi-transparent. Here’s my build:
Maybe you can share the model or a simplified version using a private message with a link to wetransfer.com? Happy to try something but not easy without the model itself.
